Renames an established This command is available on all Universal switches supported in this document. peer.
| mlag | Specifies configuring MLAG settings. |
| peer | Specifies configuring aspects of the MLAG peer switch. |
| peer_name | Current MLAG peer name. |
| name | Specifies renaming the MLAG peer. |
| new_peer_name | Specifies the new name for the MLAG peer. |
N/A.
To view changes made with this command, use the show mlag peer {peer_name} command.
# configure mlag peer mlag1 name mlag2
# show mlag peer Multi-switch Link Aggregation Peers: MLAG Peer : mlag2 VLAN : Virtual Router : Local IP Address : Peer IP Address : MLAG ports : 0 Tx-Interval : 1000 ms Checkpoint Status : Down Peer Tx-Interval : N/A ms Rx-Hellos : Tx-Hellos : Rx-Checkpoint Msgs: Tx-Checkpoint Msgs: Rx-Hello Errors : Tx-Hello Errors : Hello Timeouts : N/A Checkpoint Errors : Up Time : N/A Peer Conn.Failures: N/A Local MAC : 00:04:96:9b:f5:cc Peer MAC : None Config'd LACP MAC : None Current LACP MAC : 00:04:96:9b:f5:cc Authentication : None Alternate path information: None
This command was first available in ExtremeXOS 33.1.1.
